securitywarehouse Posted May 10, 2010 Posted May 10, 2010 I have just orderd a ADE Optima gen4 8 zone from you. It will replace a c&k Active 5. I have the Engineers code for engineering mode. The problem is I can not stop the bell box from sounding when I disconect the bell wiring or when I try to open the bell box. The bell box was fitted and suppled by Abacus and is about 3 years old. I hope you can advise . Kind regards Quote
Secware_Tech6 Posted May 10, 2010 Posted May 10, 2010 That is the protection of the system. Amy correctly installed system should do as you describe. The only way to stop it is to disconnect the internal sounder battery. this can only be done AFTER the cover has been removed. Quote
