securitywarehouse Posted April 27, 2010 Posted April 27, 2010 I'm installing a stand alone door access system and need to know if I use a max reader, would I be able to operate this with the existing key fobs used to operate the intruder alarm max reader. The reader contolling the door would have no connection with intruder alarm system at all. Quote
Secware_Tech6 Posted April 27, 2010 Posted April 27, 2010 if you currently have the black slate type with the max numberĀ stamped on them then yes. if the fobs have no numbers then no. you will also need a new master fob and 2 additional fobs for add / delete masters Quote
