Secware2 Posted February 4, 2021 Posted February 4, 2021 I recently purchased a Aritech photoelectric smoke detector with c/o relay output DP721R, I was wondering if you could recommend a suitable testing kit for this particular detector. Quote
Secware_Tech6 Posted February 4, 2021 Posted February 4, 2021 The best way to test smoke detectors is with a solo test kit. No Climb Solo 823 Smoke & Cordless Heat Detector Test Set 9.3 m [SOLO823-101] You can just use Smoke Sabre Smoke Detector Tester SS-01 - Security Warehouse but be careful of the amount used as all testing sprays will clog the detection chamber if overused Quote
