Secware2 Posted May 4, 2020 Posted May 4, 2020 I currently have a GJD 2 Zone Solitaire one of the zones the light keeps getting stuck on once activated and does not turn off unless manually turned off at the panel. It has been suggested I may need to replace the zone controller, would the dygizone be a straight swap for the solitaire as I cannot find that model anywhere . Quote
Secware_Tech6 Posted May 4, 2020 Posted May 4, 2020 No the solitaire is a built in controller and remote, whereas the digizone is just a remote. How is it cabled? ie where are the cables currently run Quote
