Secware2 Posted April 2, 2020 Posted April 2, 2020 Hi there, I am looking for a solution if possible for when my customers intruder alarm activates for it to be able to switch on external floodlights? Is this possible with your single control zone unit ie 1803 range or similar. It will be attached to a Texecom Veritas Excel Intruder panel , possibly connected to the bell -ve trigger. Quote
Secware_Tech6 Posted April 2, 2020 Posted April 2, 2020 You can use a voltek switcher but you will need a resistor to the s teminal and a switch input on the r terminal. however you could just use a relay with a 12v coil ie https://www.securitywarehouse.co.uk/catalog/access-control-c-27/access-control-ancillaries-c-27_43/tkc-very-handy-little-relay-p-5190.html Quote
