Secware Posted January 28, 2020 Share Posted January 28, 2020 Will these Optex Battery Powered 4 Channel Synchro Twin 30m Active Beam work with The new Visonic powermaster GTX kit https://www.securitywarehouse.co.uk/catalog/intruder-alarm-c-36/active-beams-c-36_142/optex-battery-powered-4-channel-synchro-twin-30m-active-beam-p-3371.html Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted January 28, 2020 Share Posted January 28, 2020 I've not tested that combination but you will require a standalone compatible tx fir the visonic. The beam is just the detector for connecting to a standalone tx Quote Link to comment Share on other sites More sharing options...
