kyrusdemnati Posted May 4, 2019 Posted May 4, 2019 Can anyone please advise? i have checked manual/interface its daunting i just need to know the basics please, everything is already in place - but .i changed my front door and the door sensor caused an issue/tamper and the alarm wouldnt set, and i made the mistake of resetting the device so i have lost all the devices from the memory thanks Quote
kyrusdemnati Posted May 5, 2019 Author Posted May 5, 2019 it looks like my door sensor is damaged, i cant open the device - screw seems damaged so i can't repair and the backplate is broken slightly (i had my door changed) i have managed to pair my 4 pir motion sensors again all set for (zone A) kitchen, lounge, upstairs landing, bedroom - will add my front door (awaiting replacement sensor) I want to also set a night alarm (Zone b for downstairs which would be (kitchen) (lounge) (and front door (awaiting replacement sensor) is it a simple process to create a zone b? my questions are going forward. 1) i am going to order a new door sensor - is this quite straight forward to install? this would need to be configured as part of zone a and zone b 2) my bellbox is also not on the panel and needs repairing, do i need to get a ladder and resync or is there an easier way? does this have a similar pairing button that is found on the sensors which i press to sync, but i use learning devices bell option on the enforcer settngs right? 3) if i buy a Pyronix Enforcer Keyfob-WE - does this only work within the proximity of my home? I would just want to use this to set alarm/disarm, set zone a, set zone b, and panic alarm... thank you Quote
Secware_Tech6 Posted May 6, 2019 Posted May 6, 2019 1 yes just add it and program as required 2 assuming wireless Bell yes 3 yes only when in range Quote
kyrusdemnati Posted May 7, 2019 Author Posted May 7, 2019 Hi mate ok thanks so at the moment I have set up to motion sensors , kitchen and lounge I tested it and it works with the alarm triggering from the unit panel. (Still need to get a ladder and do bell box) but when I try and set the alarm again it brings up a kitchen error alert and it cannot set alarm . How do I reset this ... (my test was via the kitchen motion sensor ) What options do I need to select for each my sensors too, I’m not sure if I have done it right . What do I need to set as the type type Motion sensor 1 kitchen Intruder 06 motion sensor 2 lounge Intruder 06 (My other motions sensors will be ) upstairs landing sensor what input type ? bedroom sensor what input type ? Front Door sensor (this will be my entrance and exit to the house what input type do i need ? I also will be adding a 2nd door sensor to my patio door at the back house what input type do I need to set this too ? Thanks Quote
Secware_Tech6 Posted May 8, 2019 Posted May 8, 2019 I'd suggest you start a new topic per question. It's getting difficult to follow? Quote
