July 21, 20179 yr Can you advise which security panel would be suitable to replace one which has failed? (only lasted 15 years, but sadly now defunct!)This unit has 6 zones (hard-wired) of which I use 4. Anything that offers similar, at least 4 hard-wired + radio to cover areas not currently covered would do. Can you suggest something?I can install it.
July 21, 20179 yr If you want hybrid, hard wired and radio then id look at the galaxy rf kit or the hkc 1070. If just hard wired then accenta gen4
