I need help to configure a hardwired alarm system.
I'm interested in:
1 pcs Honeywell Galaxy Flex with GSM/GPRS
7 pcs Pet immune PIR detectors
2 pcs Microtech Galaxy MK8 Keyprox LCD Keypad
1 pcs Indoor siren
1 pcs outdoor siren
I'm not sure which model of Honeywell galaxy flex I need (20 or 50?)
1. Can you please help an come up with a suggestion of which would be the right choice for me, with the above mentioned spec.
2. If I would like to add the possibility to also add wireless door sensors, what would I need to choose?
3. If I would like to add the possibility to access the alarm system with an app. What would I need to choose?
Will it be possible to install all the following equipment internally in the same panel Galaxy Flex 50 (C006-E2-K04):
Galaxy Flex GSM/GPRS Module (A081-00-01)
Galaxy Flex Direct mount RF Portal (A073-00-01)
Ethernet Module IB (A083-00-01)
Yuasa Battery 12 V 7Ah
Or do I have to choose between eighter GSM/GPRS or the Ethernet Module? Or is it only unnecessary to have both of them?
The most important for me is to be able to send messages to several phones if the alarm is triggered.
If you only wantsto send notifications to a mobile phone, there is no need - yet - for an ethernet module.
The current version of the smartphone app does not receive push notifications.
The SMS signaling can be done through the GSM / GPRS module, to up to 3 different numbers.
All the modules can be fitted in the enclosure, just make sure it is a Medium size.
