old pyronix magnum spp passive
Hi
Could you tell me what passive would replace this one as it has 3 extra connections to the normal 6.
These are marked C+ , E- , and FTA.
There is a wire looped from the power minus connection to the FTA connection and a brown wire in the cable connected to the C+ connection.
What is the purpose of these extra connections ?
The reason for replacement is that this passive leaves the led indicator on permanently which doesn't seem correct.
I have always used risco quads in my own setup and they seem very reliable.
Would one of these fit the bill ?
The panel is a Scantronic 9800.
Hoping someone can point me in the right direction for a replacement.
Thanks in advance  Kevin
Without Knowing the sensor its hard to say
Id suggest that FTA is first to alarm. THis would suggest there is more than 1 sensor on the zone and the device is latching
E- could be LED Enable -
C+ i dont know.
Risco quads are good units, i personally wouldnt always spec a quad in a domestic, unless there was a reason. Usually go for a good dual edge PIR
