Hi there
I have an MCR-304 + 3 x MCT-303's in my basket.
2/. From your experience in the field what is the effective range. In my application I have a fair amount of brickwork through which the RF must travel - probably about 15M to the furthest 303 and about 3 x 9" conventional brick walls.
3/. Are the 303's 'supervised transmitters'.
Thanks.
2. Impossible to answer I've seen 200m but also I've seen 35m only way to tell is to test. I use the hkc test kit but the hkc does have a higher tx output
3. It's not the tx that is supervised as such the rx makes that decision. Use caution with any one way device the best thing is to use 2 way gear like Honeywell, hkc or vanderbilt
