November 21, 20169 yr Hello.Do you have an Intellisense IQ260 replacement/equivalent please.I have one in my garage, after doing some refurbishment to the building I was thinking of installing an additional sensor as a single one can no longer cover the area.That is if 2 pir's be installed in the same zone/room? an 8 core cable is installed however only 1 core remains unused.If 2 can be used on same cable maybe better to buy two identical detectors and do away with the IQ260?Thank you.
November 22, 20169 yr I would look at the honeywell dt with mirror optics. The old iq is long obsolete.
