Secware Posted June 20, 2016 Posted June 20, 2016 Can you tellme what battery will fit the honeywell large plastic cased accent gen4 with key pad and also can the honeywell compact per with pet immunity be used as a normal pic or will i have to order a honeywell IS3016 so it matches. Thanks. Quote
Secware_Tech6 Posted June 21, 2016 Posted June 21, 2016 It will take upto a 7A/h and yes with the sensor they are just a little slower Quote
