Looking for a panel that can control a relay whereby when the alarm is set, e.g. when leaving the building, a signal is sent from the panel to a relay. This signal causes the relay to switch and so makes another device active. The signal stays continuous whilst the panel is set. Conversly, when the panel is un-set, the signal is withdrawn and so the relay becomes inactive.
Looking for a low cost compact wired model preferrably. Which model do you recommend?
Thanks
