May 6, 201610 yr Good morning,Thank you for your email regarding the cover for my Flash Guard sounder.I am quite happy to purchase a new unit but would like to know if the six core cable that controlled the old unit will be ok for a new one.I have included a photo of the old unit and to which colour went to which connection on the vertical block located on the left of the photo.1- Yellow (Tamp out)2- White (Tamp in)3-4- Blue (Supply minus)5-6- Green (Trigger)7- Red (Strobe plus)8- Black (Trobe minus)There was then a Red coming from a battery going to the plus connection on the small terminal block.I hope this will help in recommending the right sounder for my application.
May 6, 201610 yr You will need to rewire it at the panel end possibly but 6 core is fine, what control panel you connecting to?
