February 15, 201610 yr I'm look for some shock sensors (to be fitted to window frames) preferably wired and that work with DSC PC range.I was looking at the Aritech GS612 but I've not had much joy with it albeit the door sensor with magnet works fine.
February 16, 201610 yr No as far as I know it's not, I'm using a DSC PC1832 panel. I believe my options are either to fit an analyser board or replace the sensors with a different option. Perhaps you could make a recommendation or have sales contact me? Many thanks.
