Secware Posted February 15, 2016 Share Posted February 15, 2016 I'm look for some shock sensors (to be fitted to window frames) preferably wired and that work with DSC PC range.I was looking at the Aritech GS612 but I've not had much joy with it albeit the door sensor with magnet works fine. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 16, 2016 Share Posted February 16, 2016 Those detectors need an analyser. You are using a panel that does? Quote Link to comment Share on other sites More sharing options...
raouls Posted February 16, 2016 Share Posted February 16, 2016 No as far as I know it's not, I'm using a DSC PC1832 panel. I believe my options are either to fit an analyser board or replace the sensors with a different option. Perhaps you could make a recommendation or have sales contact me? Many thanks. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 17, 2016 Share Posted February 17, 2016 If you have power at the detectors id recommend the Honeywell viper Quote Link to comment Share on other sites More sharing options...
