Secware Posted February 8, 2016 Posted February 8, 2016 o whom it may concernI was looking through you web side regarding the Honeywell Model G2K3WR-01-Cand i would like to ask the following question1 when system set off I;m able to set t to call the police station and other numbers? and should be connected with GSM or landline?2 I'm able to connect wireless movement detectors and wired detectors at the same time?3 the system will be provided with installation manual and user manual?if the above not possible, could you please guide to the another Model with allows the above.hope to hear from you soonThanks & Regards Quote
Secware_Tech6 Posted February 9, 2016 Posted February 9, 2016 No you cannot set any system to autodial the police without a urn. Quote
stuart_mcg Posted February 9, 2016 Posted February 9, 2016 1. No - as above, you cannot connect to the police - nobody can - alarms must connect to alarm receiving centers and only approved installers systems can then (and only if a set of rules are met) get a police response. The response will also be removed if too many false alarms in a 1yr window. 2. Yes, but you need the RF portal 3. Search google for galaxy g2 installation manual You can self monitor this panel by adding in an ethernet module and using an IP based service like selfmon Quote
