Secware Posted January 26, 2016 Share Posted January 26, 2016 Hi, I have a texecom PIR which has a normally closed relay, unfortunately I have a voice off device which plays MP3s when triggered. This requires a Normally Open input which closes to trigger the MP3.Is there an off the shelf device which would convert this PIR from Normally Closed to Normally Open input?Many Thanks Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted January 26, 2016 Share Posted January 26, 2016 You could use a relay to convert. Quote Link to comment Share on other sites More sharing options...
