Secware Posted January 26, 2016 Posted January 26, 2016 Hi, I have a texecom PIR which has a normally closed relay, unfortunately I have a voice off device which plays MP3s when triggered. This requires a Normally Open input which closes to trigger the MP3.Is there an off the shelf device which would convert this PIR from Normally Closed to Normally Open input?Many Thanks Quote
Secware_Tech6 Posted January 26, 2016 Posted January 26, 2016 You could use a relay to convert. Quote
