December 18, 201510 yr Purchased a 760ES and has the following problems; "The Siren is proper teached to the Control Unit with a high signal level. The Control Unit respont correctly to the two tamper switches wehnever they will be activated.The Siren dosen`t sound and flashes. It also dosen`t sounds when the Batterie will plug in. (referring to Info on Page 3 Installation Guide)It doesen`t sounds and flashes when the tamper switches will be activated." Can you confirm if the Siren would be faulty?
