Secware Posted November 26, 2015 Share Posted November 26, 2015 The instructions for this unit says that if the settings are changed the unit must be reset at the control Panel. I purchased these units to replace my existing unit and therefore do not have a Honeywell control unit or any functionality to reset PIRs. Can you tell what the reset process is?The anti - mask function, sounds a bit like anti-tamper, do you see any reason why the anti tamper and anti-mask relay out puts cannot be connected in series and both be in the anti-tamper circuit? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted November 26, 2015 Share Posted November 26, 2015 They dont need to be on a honeywell panel. The reset will mean powering it down so it gets the new settings on power up. Yes no reason at all Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted November 26, 2015 Share Posted November 26, 2015 Assuming its not a grade 3 system as the mask has to be reported seperatly to comply. Quote Link to comment Share on other sites More sharing options...
