Secware Posted November 26, 2015 Posted November 26, 2015 The instructions for this unit says that if the settings are changed the unit must be reset at the control Panel. I purchased these units to replace my existing unit and therefore do not have a Honeywell control unit or any functionality to reset PIRs. Can you tell what the reset process is?The anti - mask function, sounds a bit like anti-tamper, do you see any reason why the anti tamper and anti-mask relay out puts cannot be connected in series and both be in the anti-tamper circuit? Quote
Secware_Tech6 Posted November 26, 2015 Posted November 26, 2015 They dont need to be on a honeywell panel. The reset will mean powering it down so it gets the new settings on power up. Yes no reason at all Quote
Secware_Tech6 Posted November 26, 2015 Posted November 26, 2015 Assuming its not a grade 3 system as the mask has to be reported seperatly to comply. Quote
