Secware Posted November 4, 2015 Share Posted November 4, 2015 Hello,I have purchased a CQR 3/8 Flush Contact 1 RD 4 Wire White, but it does not work on my door. Most probably, it's because the gap est too large and the metal door interfere with the contact detection. I am looking buying a new flush contact. Which one do you recommand? You have so many.The installation environnement is: metalic door, large gap (difficult to measure, probably at least 10mm), if possible a contact with direct wiring.Looking forward your answer Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted November 4, 2015 Share Posted November 4, 2015 Direct wiring do you mean built in eol? I wouldn't recommend any flush contact at that gap on a steel door. The magnets cant be big enough Quote Link to comment Share on other sites More sharing options...
jalex Posted November 5, 2015 Share Posted November 5, 2015 Thanks for your answer. Do you have any mechanical contact to recommand? regards Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted November 6, 2015 Share Posted November 6, 2015 Yes id go with the large mag knight multi Quote Link to comment Share on other sites More sharing options...
