Secware Posted October 19, 2015 Posted October 19, 2015 HiI have a securilite alarm system fitted with the IBX Command centre in the house which has Single head PIR sensor outside to cover the drive way, the sensor has failed and i cannot see any part numbers on the sensor and i am unsure which one to order from you, it looks identical to the voltek sensors you list but which one ? would the Voltek 1804 single head sensor be suitable for this with the range of 18m x 90 degree angle ?Kind regards Quote
Secware_Tech6 Posted October 19, 2015 Posted October 19, 2015 A picture would confirm it. Are you sure its the Pir not the switcher? Quote
