September 9, 201511 yr Hi,I already have a Galaxy G2-44 with :2 Keyprox - MK7 & MK81 RF Portal - C079-21 Internal siren5 wireless motion sensors - Honeywell DTPI8M4 wireless door contacts - Honeywell DO8M6 wireless Smoke Sensors - Honeywell DF8M2 Wireless CO sensors - Honeywell CO8MI want to add a Honeywell ECO1005-A to this system as there is not a wireless heat-rising sensor for this system that I can find. First, it's wired so will it work OK with the wireless sensors or will there be any conflicts? Also, do I need a latching or non-latching base for this?Hope you can help and thanks,
September 9, 201511 yr Assuming you have a spare wired circuit then yes, you want the non latching version
September 12, 201511 yr And also, its wired with 4 core wire? I have some wire I used for the RS485 bus lying around and could use that. Is that OK? Thanks again!
