Secware Posted July 10, 2015 Share Posted July 10, 2015 just installed above pir in a conservatory and there are cats it activated 3 times with and without cats is there any settings I should set for a small conservatory? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted July 10, 2015 Share Posted July 10, 2015 Have you adjusted the range down, set for harsh on Pir and mic? What pet mode is it in? And can the cats get within 6 Ft of the detector? Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted July 19, 2015 Share Posted July 19, 2015 Please whoever is reporting content about this topic you need to reply not report Quote Link to comment Share on other sites More sharing options...
Secware Posted July 20, 2015 Author Share Posted July 20, 2015 my last ticket has been closed as I sent another query and not had a reply the setting is set to hazard and turned down I have pet set to 30 kgs twice the cats not in the conservatorythe red and yellow lights have to be on is this correct Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted July 20, 2015 Share Posted July 20, 2015 The red led is the activation (ie relay) indicator and the yellow is the microwave. All indicators should be off when there is no movement Quote Link to comment Share on other sites More sharing options...
