[Ticket Question] Gen 4 Mini Zone Inhibit Problem
Secware
I have just installed an Accenta Mini Gen 4. I am using zone 2 on the panel as as inhibited (default setting) when I set the panel it show zone 2 as an error as it detects the operator in the exit zone. The alarm sets ok after you exit the property as the error clears. Upon re-entry zone 2 is inhibited ok as the alarm is not activated. I would have thought that the zone 2 should also be inhibited in the exit mode and not show an error on the panel. Is this correct.
