Secware Posted June 3, 2015 Posted June 3, 2015 Hi there, i bought one of these pirs in my last order. I fit it and was sure it was working but i tested it the other day and it doesnt seem to be working correctly. It does not trigger the alarm, seems that it is permanently closed. Is there something i need to do, ie change the factory settings on the sensor or does it need returning?Regards Quote
Secware_Tech6 Posted June 3, 2015 Posted June 3, 2015 Could you upload a picture of the wiring, the dip switch/jumpers and what panel you are using please Quote
Secware_Tech6 Posted June 10, 2015 Posted June 10, 2015 It looks like you have wired it double pole but configured your detector for eol use. Change the jumpers for non eol use and you should be ok Quote
Stephenferguson Posted June 12, 2015 Posted June 12, 2015 How do i configure for non eol, Regards Quote
Secware_Tech6 Posted June 12, 2015 Posted June 12, 2015 The detector manual will show how. You need to remove the eol jumpers Quote
