smash0007 Posted October 16, 2009 Posted October 16, 2009 hi, could anyone inform me to which type of battery to use in a scantronic 9448+ style pannel with the correct diamentions, many thanks smash0007. Quote
Secware Posted October 16, 2009 Posted October 16, 2009 Hi, The 9448 panel takes a 12v 2.3amp battery and the dimensions for the control panel are W 212 x H 212 x D 68mm, just for your interest the key pad is W 115 x H 15 x D 28mm Hope this helps with your query Regards Elaine Quote
Secware Posted October 23, 2009 Posted October 23, 2009 Hi, I have just re reread your question, and I have given you the measurements for the control panel and you was after the battery dimentions which are H 6cm W 17 1\2cm D 3 1/4cm, so sorry for the mix up, hope this helps you. Regards Elaine Quote
Secware_Tech6 Posted October 30, 2009 Posted October 30, 2009 smash as above only a 2.1 - 2.3 A/h will fit inside a 9448 Tech Support Quote
