Nick Posted August 21, 2009 Posted August 21, 2009 Hi, I would like to fit a driveway alert (preferably wireless) so probably a narrow beam pir type thing, plus a gate openining alert. Basically when the gate opens or someone walks in the drive I would like a buzzer to go off inside the house. Is there an idiots kit? Quote
Secware_Tech6 Posted August 21, 2009 Posted August 21, 2009 nick There isnt an idiots kit as you put it, but it is entirly possible. Id start with a gjd or voltek lighting system and add the detectors required. Alternativly you cold start with a normal intruder alarm control panel and add the required detectors. Suport Quote
Ian Paul Posted September 17, 2009 Posted September 17, 2009 Hi, I supply wireless only systems. Prices from Quote
Secware Posted September 18, 2009 Posted September 18, 2009 Hi Nick Another way you could do your drive is by using a Takex TBIN75SW which is a wirless beam the cost is Quote
Nick Posted October 8, 2009 Author Posted October 8, 2009 THank you for the responses. It is nicethat people take the trouble! Quote
