Secware Posted July 28, 2009 Posted July 28, 2009 Hi I am sorry to say that the power max will only do english, you are best to purchase it from Sweden for the correct speech and phone cards Hope this helps with your question Regards Elaine Quote
Secware_Tech6 Posted July 29, 2009 Posted July 29, 2009 As above we only stock the UK varients. Its not a programming option to chnage the language it needs the panel reflashing to the correct firmware. A UK varient will work in any country but will obviously use UK text and speech. As a side note I personnly couldnt support a non english unit as i wouldnt understand the logs etc James Quote
Mans Posted July 31, 2009 Posted July 31, 2009 Hi I checked with the Scandinavian headquarter, they told me that they dont flash it into swedish. But you can down load the swedish manual and when everythings install its no problem running it in english. Quote
