I'm fairly sure I can interface the Reson8 bell box to an old RS alarm Panel I installed many years ago. The panel has (in order) + Hold off, - Hold off, -SW, +SW, -ExB, -ST-, + IntBell, - IntBell, +Buzz, -Buzz, -Tamp(Zone1),+Tamp(Zone1)
Basically I cannot see how to connect the Tamper supply- and Tamper return- in the Wiring diagram. I am sticking with the wiring colours. I know it's quite serviceable.
Those are designed for panels with an SABT input. ID suggest due to the age and or non standard panel you have it doesn not have these inputs.
You will need to wire the tamp return to a relay and wire the clean contacts of that relay into the tamper on zone 1. ID also be sure that the panel has the power to run a SAB unit
