July 7, 200917 yr Dear Support, Would you know the jumper settings for a Risco Gardtec 595 / 800 Series Zone Expander card? There is a bank of 8 called ZEX1 through to ZEX8, J9 (ZEX Type) and J10 (ZEX Group). Are these in a manual somewhere as I can't find them in the 595 manual I have. Grateful if you can help.. Many thanks. Roy.
July 15, 200916 yr Hi Roy I have asked our Tech Support to check this out for you, we will get back asap Hope this helps Kindest regards Elaine
July 15, 200916 yr this is so u can label the zex (zone expander) if u have more than 1. hope this helps u good luck
July 15, 200916 yr Author Dear support, Thanks for the response, I thought the bank of 8 were for card ID but what about J9 (ZEX Type) and J10 (ZEX Group)? Roy.
July 21, 200916 yr Author Dear Support, I'm still waiting on clarification on the zone expander card as above. Is there any sort of documentation available for the card? RoyP
July 21, 200916 yr Hi I have contacted the manufacturers to see what information is available for you, will post a reply as soon as we have anything to help you A
July 23, 200916 yr Hi Roy The J9 and the J10 are not in use, I have spoken to the supplier for this information Hope that answers your question now Roy Good luck Regards Elaine
