Secware Posted June 3, 2013 Posted June 3, 2013 My question is this. Are all the biscuits in an 11-20 blue-pack (as above) the same, apart from the numbered stickers, or is the internal wiring different? I ask because I've just broken a No 20 while attempting to replace a doorbell plate. Can I use another biscuit from the same pack as a replacement, or will this upset my alarm system? Sorry if this is a stupid question, but I'm no expert. I've asked for high-priority because my house alarm is disabled by the problem. Quote
Secware Posted June 3, 2013 Author Posted June 3, 2013 If this is programmed as 20, this will need to be another 20 as a direct replacement. Quote
accounts3 Posted July 4, 2013 Posted July 4, 2013 The resisitor in each one is different, so you will need to reprogramme or use a new number 20, as above Quote
