February 28, 201313 yr I assume with the keypad I 1. open cover 2. disconnect wires (making note of what goes where) 3. wire up new keypad 4. replace cover, enter user code and test alarm
May 16, 201313 yr The battery change is quite simple, open the CP cover, enter code to stop the tamper signal, fit battery same size as exisitng, ensuring the red and balck connections are correctly fitted. Close cover, and test system
