Secware Posted January 30, 2013 Posted January 30, 2013 i was thinking that i could use some wire and connect the auxiliary input of MC-302E PG2 with a outdoor PIR sensor but i don't know if this could be done.I was thinking of the OPTEX BX80 NR (maybe if it fits i install the MC302E PG2 inside the BX80NR)cause i can't imagine a way to have my balcony covered (12x2,4m) with the TOWER 20AM PG2. Do you think i could do such a thing? or what other option i have to cover this area with Visonic compatible product ? Quote
Secware_Tech6 Posted February 16, 2013 Posted February 16, 2013 If your planning on using this to activate the alarm i would advise against it. But you could use an optex or takex infrared beam instead on your panel Quote
