Secware Posted January 14, 2013 Posted January 14, 2013 I have just completed an instalation of a accenta G4 from yourselves,on powering up i can reset the alarm by entering factory user code but the display on the 2 LCD keypads is all black squares,please can you advise any help checked wiring but all seems correct with panel and both keypads. Quote
Secware Posted January 14, 2013 Author Posted January 14, 2013 Here is what you can try. 1. Check the voltage at the keypad between 0v and Comm, it should be 5v dc. 2. Power down and power up the panel with battery first and then mains. 3. Try connecting just one keypad once. 1 Quote
Secware_Tech6 Posted January 20, 2013 Posted January 20, 2013 As above you may have a data issue. Tryu connecting just one keypad on a short temporary length of cable at the control panel Quote
