Secware Posted November 19, 2012 Posted November 19, 2012 I purchased an ade Optima Compact alarm system which I have fitted all seemed fine until I tried to alter the customer code from **** it would not accept the change but stopped the system from working. I have tried resetting the system back to factory settings as outlined in the manual but it does not work when the alarm is powered up it goes right into alarm but no LED lights show (not even the battery power)and the code **** does not rest/stop the alarm. Quote
Secware_Tech6 Posted December 11, 2012 Posted December 11, 2012 You have chnaged the code from default to something else (miskeyed perhaps) A factory default will if done correctly put this back to how it was out of the box Quote
