[Ticket Question] Honeywell Viper Glx Led Not Working?
Secware
viper led not flashing, installed 14 no viper gxl set dil switch 1 off dil switch 2 on all leds flashing ok for three days checked wiring ok checked voltage ok viper led flashed ok for approx 20 mins then stopped viper works on alarm test , just led not working on this viper
Hi,
Please follow the following 7 core wiring of the viper glx for LED indication :
Dip switch 1 : ON
Dip switch 2 : OFF
Terminal
no Viper GLX Panel
1 alarm zone
2 alarm terminals
3 tamp tamper
4 tamp terminals
5 12V 12V power supply
6 0V
7 SET should be connected to an output in
the panel, which gives 12V when the panel is SET
8 FTA not used
  • 2 months later...
  • 2 years later...
