May 30, 201214 yr viper led not flashing, installed 14 no viper gxl set dil switch 1 off dil switch 2 on all leds flashing ok for three days checked wiring ok checked voltage ok viper led flashed ok for approx 20 mins then stopped viper works on alarm test , just led not working on this viper
June 1, 201214 yr Author Hi, Please follow the following 7 core wiring of the viper glx for LED indication : Dip switch 1 : ON Dip switch 2 : OFF Terminal no Viper GLX Panel 1 alarm zone 2 alarm terminals 3 tamp tamper 4 tamp terminals 5 12V 12V power supply 6 0V 7 SET should be connected to an output in the panel, which gives 12V when the panel is SET 8 FTA not used
June 6, 201214 yr Author 6 no vipergxl on one zone, last viper led not working ,wired in 6 core , ps led on viper no 6 worked ok for approx 3 days ,checked power ok .alarm test ok other 5 vipers led ok
August 19, 201213 yr Can you upload a pic of a working unit and the non working unit so i can see the programming switches and the wiring setup please
November 21, 201411 yr How do i stop the LED indicator light flashing on the Viper GLX? Customer complaining bothers them at night because it is on patio doors in bedroom
