Secware Posted May 30, 2012 Posted May 30, 2012 viper led not flashing, installed 14 no viper gxl set dil switch 1 off dil switch 2 on all leds flashing ok for three days checked wiring ok checked voltage ok viper led flashed ok for approx 20 mins then stopped viper works on alarm test , just led not working on this viper Quote
Secware Posted June 1, 2012 Author Posted June 1, 2012 Hi, Please follow the following 7 core wiring of the viper glx for LED indication : Dip switch 1 : ON Dip switch 2 : OFF Terminal no Viper GLX Panel 1 alarm zone 2 alarm terminals 3 tamp tamper 4 tamp terminals 5 12V 12V power supply 6 0V 7 SET should be connected to an output in the panel, which gives 12V when the panel is SET 8 FTA not used Quote
Secware Posted June 6, 2012 Author Posted June 6, 2012 6 no vipergxl on one zone, last viper led not working ,wired in 6 core , ps led on viper no 6 worked ok for approx 3 days ,checked power ok .alarm test ok other 5 vipers led ok Quote
Secware_Tech6 Posted August 19, 2012 Posted August 19, 2012 Can you upload a pic of a working unit and the non working unit so i can see the programming switches and the wiring setup please Quote
winton Posted November 21, 2014 Posted November 21, 2014 How do i stop the LED indicator light flashing on the Viper GLX? Customer complaining bothers them at night because it is on patio doors in bedroom Quote
admin Posted November 27, 2014 Posted November 27, 2014 connect the vr input and program the panel to reset on disarm Quote
