Secware Posted May 23, 2012 Posted May 23, 2012 Only zones 1,4,5 used .zone 1 is the exit/entry zone .All PIR detectors work on walk test and zone 1 works in chime mode.The alarm sets OK system bleeping until set . when the entry zone ( 1 ) operates it goes straight to alarm , after reset code entered the panel has zone 1 flashing only. Quote
Secware Posted May 23, 2012 Author Posted May 23, 2012 Link out the unused zones, even if the zones are disabled and then try it again. Quote
Secware_Tech6 Posted August 19, 2012 Posted August 19, 2012 What is your entry time programmed as? Quote
