Secware Posted May 21, 2012 Posted May 21, 2012 fitted new panel no problems, but unable to get entry time to work full alarm goes off as soon as door opened . tried setting up as described in engineer's manual page 38 . Is it something I'am doing or is the panel faulty ? Quote
Secware Posted May 22, 2012 Author Posted May 22, 2012 When you set the panel, and you trip the front door, the panel goes into alarm, and you put in your code in the keypad to silence the alarm. After that you need to check which leds on the keypad are lit solid and which leds are flashing. The one that is flashing is the first zone to go into alarm, followed by the zone leds which are solid. This will help to find out which is the first zone you tripping. Quote
Secware_Tech6 Posted August 19, 2012 Posted August 19, 2012 Im assuming you are only using zone 1, and you have wired into the detection zone and not the tamper zone? Quote
