My problem is an Optima Compact giving spurious tamper alarms on the control panel. These are totally random and alerting the internal sounder not the outside alarm box when in day mode. The strobe flashes when this event occurs but as I say no alarm. When the system is set the alarm box works normally. On a suggestion I have changed the alarm panel battery .
Spurious alarms from the panel seemed cured for 10 days but now have returned . Any possible answer to the issue appreciated.
You need to narrow down which tamper is the issue.
ID loop out the global tamper, keypad tamer (if a gen4) and SAB tamper.
If you can upload a photo of your board i can see which tampers are in use.
