March 13, 201214 yr Good morning, I have just received a new 723r I purchased to replace an old one I'd had which was broken. Could you please advise how to connect it to my Homelink 75 unit, I've tried following the Homelink instructions but it doesn't seem to work. Thank you
March 14, 201214 yr Adding or replacing user fobs is a manager function. Is the local led on the unit working, ie is the battery installed correctly. WHat process are you using to add the fob?
