Secware Posted February 29, 2012 Posted February 29, 2012 I'm interested in a Visonic Powermaster 10 Kit with additional peripherals. However, there are a few questions I haven't found information about. - The system has partition support but still only can handle one partition according to the brochure. How come? - Is the central proximity tag compatible out of the box or do you need a remote keypad? - Is your kit supplied with Euro mains plug? - If not connected to a monitoring centre is the alarm info sent only by SMS to numbers by choice or is there also voice dialing involved? Quote
Secware_Tech6 Posted March 2, 2012 Posted March 2, 2012 - The system has partition support but still only can handle one partition according to the brochure. How come? The smaller panel can only handle 1 partition, but i wonder if your mixing up part set and partition. If you need more than 1 partition you need the more powerful panel. A partition in this case is to create a separate logical system that is full set etc independently. Normally only used on commercial systems Is the central proximity tag compatible out of the box or do you need a remote keypad? Yes there is a reader in the panel If not connected to a monitoring centre is the alarm info sent only by SMSto numbers by choice or is there also voice dialing involved? It can do voice dialling but will require gsm and an active sim etc for texting Quote
