February 27, 201214 yr I'm intrested in a low cost wireless alarm system that I can connect into a PC. I would be looking at about 5 PIR sensors and 2 door sensors to start. In an ideal world multiple codes or RFID tags could be used to set unset.
February 27, 201214 yr That is an advanced function. There are many panels that can but non are low end. Can you expand on what you need from the pc connectivity?
February 28, 201214 yr Author A write out of which token/code was used to disarm and a record of any activation.
March 2, 201214 yr That is a basic logging function. Any of the higher end panels will do this. IF you dont currently have the software id look at the texecom premier range. Their software is called wintex and can be used to connect via a compatible modem. You can the download your events and print etc
