Secware Posted February 27, 2012 Share Posted February 27, 2012 I'm intrested in a low cost wireless alarm system that I can connect into a PC. I would be looking at about 5 PIR sensors and 2 door sensors to start. In an ideal world multiple codes or RFID tags could be used to set unset. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted February 27, 2012 Share Posted February 27, 2012 That is an advanced function. There are many panels that can but non are low end. Can you expand on what you need from the pc connectivity? Quote Link to comment Share on other sites More sharing options...
Secware Posted February 28, 2012 Author Share Posted February 28, 2012 A write out of which token/code was used to disarm and a record of any activation. Quote Link to comment Share on other sites More sharing options...
Secware_Tech6 Posted March 2, 2012 Share Posted March 2, 2012 That is a basic logging function. Any of the higher end panels will do this. IF you dont currently have the software id look at the texecom premier range. Their software is called wintex and can be used to connect via a compatible modem. You can the download your events and print etc Quote Link to comment Share on other sites More sharing options...
