Please can you confirm wiring details for this system:
the control is the Honeywell Galaxy Flex 20 and Honeywell IS215T PIR's
are these compatible, how do i connect these as i have only wired alarms that have a separate tamper circuit connections
do you have any wiring diagrams showing these PIR's wired singly to each zone ( 1 PIR per Zone)
It would be easier to use a pir with built in resistors. Which the is215 does not.
However it is pretty easy.
On the is215, connect one of the circuit wires to one side of the pir tamper switch. Connect a 1k resistor from the other tamper connection to the NC alarm. Connect another resistor (1k) across the alarm relay. Then connect the other circuit wire to the alarm relay connection with only 1 resistor connected.
